Oildyne Mercruiser tilt trim motor fluid recommendations
I have a 1988 4.3 with pre alpha outdrive. I have an Oildyne tilt trim motor(SAE J171 MARINE). What is the best fluid for this unit. I have replaced the fluid in the past using mercruiser clear hydraulic oil. The oil is now pinkish.(water in oil ?) I want to remove the pump and clean it up and flush the lines. What is a good replacement fluid? I have read in the forums of boaters using Ford type F tranny fluid, Motor oil non detergent and hydraulic fluid. What are your opinions? I have a link below of the picture of a pump assy<br /><br />Thanks<br />Chuck Neste<br /><br /><br /> http://www.marinetradingpost.com/yhst-53959190097415/42t1088m.html
