oiling cylinders before cranking
tbird175
A
Still preparing my 175 HP Blackmax for first cranking in several years. I plan to oil the cylinder walls with 2 cycle outboard engine oil. Should I tilt the engine as much as possible to fill the cylinder with oil or should I just spray a generous amount in each cylinder? The engine turns freely by hand.
latin monkey
Re: oiling cylinders before cranking
i would tilt it and let it sit a bit, just turn it over by hand after to get it lubed up good
