Bigprairie1
- Joined
- Jun 13, 2007
- 2,568
Ok, I'm underway with getting started on replacing the centre piston (or more?) on my '90/90hp based on Frank and Jerry's inf0o.
Quick background, this was a great running motor for several years then late last season it suddenly dropped in power a bit along with a rough idle. A quick compression test showed the centre piston was down to about 60-70psi. Then removing the head I saw the tell tale broken piston nub. There is very little time on the engine in the 'broken' ring condition so the bore doesn't appear to be scored too much.
Now its time to get this done and so I'm underway.
The heads off (pretty easy) and now I'm working on the other side of the motor. I've got most of the intake bolts off (I think) and the carbs/linkage/etc are still all attached to the intake. The gas/choke/throttle are disconnected so far....so i'm getting close to looking for the next needed advice here.
I was hoping to keep the carbs/intake intact (as previously mentioned) but it looks like the lower carb(s) might have to come off to get at those 2 little hidden/lower intake bolts?.....does this sound right?
Now in terms of intake bolts the ones I have been removing are both the direct/straight ones and the angled ones.....does this sound right? (question:...what is the idea behind the angled bolts?...just extra? or is there something else in behind?)
So guys any tips you can give me today or shortly would be greatly appreciated. I don't want to mess this up...and so far it seems like I'm on track!!!
More to come...and hopefully some pics once there is more to see.
all Good & many thanks!!
BP
BP
