Re: Ok, another (possible) piston replacement thread '90/90hp
A shop press is the best way to push out the old wrist pin. And yes it is pressed fit. The new Wiseco is not pressed fit so that should be easy to put together. I used a small dremel with a conical grind stone to chamfer the ports. No need to grind more than 32nd of an inch. I think as long as they do not feel sharp when you run your fingers should be good. Of course, if you can do 16th of an inch it will be better.
