OK Force Guru's Still no top rpm's,85 hp,,Need advice please
mrtool2u
Re: OK Force Guru's Still no top rpm's,85 hp,,Need advice please
Ok marine doctor,don't just dangle the bait in front om me,give me something to bite on. What do I need to look for.I am taking the boat out on the lake Sunday nite after work,is there anything that I can do to make sure of problem.Should I check spark on all 3 cylinders,and do you think that this sounds like a coil problem.
The Marine Doctor
Misfiring could be the powerpack...bad plug..bad wire..bad airfuel mixture.<br /><br />There is a whack of reasons why it might be seeming to fire erratically. Change the pack with another...you have 1 free one.<br /><br />TMD
mrtool2u
Marine Doctor,excuse me if I sound dense here,but what do you mean by replacing with another,you have 1 free one.I know that there is 2 packs,,can they be interchanged.Also,what would control the air fuel mixture at wot.I currently have champions in,but I am going back to the NGK buhw.
The Marine Doctor
You have 3 cyl's..and 2 packs<br /><br />1 of the packs is only driving 1 cyl. You can wire it different to use the other side if there is a problem with the packs.<br /><br />TMD
mrtool2u
Marine Doctor,is there a correct way to do this,hate to do any damage to motor.Can you use 1 pack for all 3 cylinders.
The Marine Doctor
Nope...if you pull the bracket off you will see that only 1 pack is wired for 2 cyl's while the other is only wired for 1.<br /><br />TMD
Rdecker
I'm having simular problem with my CDI packs on an 1989 - 85 hp Force. The 2 CDI units you have on your should be the same as mine and located in the same place. I will call them left and right. The right one controls cylinders 1 & 2, orange wire for #1 & red wire for #2. The left one controls cylinder #3, the orange wire for #3. It is my guess that if there were a 4th cylnder the red wire would be used. But then again it would probley use a different stator and have another coil. Hope this helps ya. Later
