Ok may sound dumb
Tennessee
But I have to ask
when I put my 1994 150 HP Johnson fast strike in reverse it makes a clicking noise and looks like the motor want to rise back up...I have no problems forward. I have checkewd the back and nothing seems loose
Also I might add that I'm not really goosing it in reverse
Can you reverse when trimmed little over half way
by the way what is a good lower unit oil for my motor
Thanks Will
Mas
Re: Ok may sound dumb
Make sure you do not "gingerly" put it in gear....your gears will wear as they try to"catch!"
MAke sure the leg is in the water so the water pump is submerged.
MAS
freddyray21
should have a reverse lock on it. The clicking may be shift linkage out of adjust which would also explain the reverse lock not engaging.
tashasdaddy
could be a cable adjustment, or the shift rod. get it fixed before you ruin your gears.
