Ok new problem NOW
spoooln30000
Boat runs for 20-30seconds then dies off. Boat was siting for few years its a 99 MErcruiser 350 2 barrel Thunderbolt 5. Would anyone like fuel pump? Also does fuel pump have power when on run position on key switch? Or a electric problem? Thanks someone help
cooter2506
Re: Ok new problem NOW
electric fuell pump? If so i would suspect either the wiring at the oil pressure switch or the switch itself. That switch sends power to the fuel pump in the run position. When the key is turned to start it runs the pump till you let off key in the run positiion then the switch takes over.
spoooln30000
My oil pressure gauge works ok tho? Would that still have issues with fuel pump? I checked the power to pump with test light no power or is it less then 12volts and I couldnt read it?Thanks for help
Bt Doctur
go to the Adults Only section and download the manual for your application,read up on the fuel system section to have a better understanding on how the elec pump is wired.
spoooln30000
I already did I see wire goes from Battery to starter then oil sensor the over to fuel pump. Is that sensor different from the oil pressure sensor on dash board? Thanks
Don S
Yes, it's an oil pressure switch, not a gauge sender. Should be down on the port/aft part of the block with 2 wires going to it.
spoooln30000
If I by pass it and boat runs then sensor correct? If I remove it will oil leak everywhere from it?Thanks
6meter
Oil will pi$$ out of there if you start it. Not running, no oil flow. That oil pressure switch is there to kill the fuel pump when you have no oil pressure. Bypassing it may start the motor but you might not have any oil pressure. Be careful there, its a built-in safety.
jtmarten
To test the switch you can connect the 2 wires together. If it starts, the switch is bad. I wouldn't run any more than testing this way though.
Ayuh,.... That's Correct...
When you change it, it'll drip abit, Not alot....
