OK OK BIG ??? no Bow eye 26ft chris craft
MaverickGrabber
Have a 88 Amerosport 262 has no bow eye ....can i just drill and put one on ??? do i need to brace it more on the inside ??
Mischief Managed
Re: OK OK BIG ??? no Bow eye 26ft chris craft
It must be braced properly on the inside. It will require a large backing plate. This is not something you should approach lightly; there's usually a huge amount of stress applied to this hardware on a 26 foot boat, and a failure there can cause serious damage and/or injury.
Ayuh,... Boats that big usually don't have bow-eyes...
I put 1 into my 34' houseboat last year,...
1/2" diameter SSteel,+ tied it into the anchor tie-in...
MaverickGrabber
thanks how did you tie it into the anchor line?? ....had a guy tell me to just drill the hole and put it in with the little plate it comes with .just did not see how that could hold .......thinking ..could bend a steel plate the shape of the bow ..have it cover 8 inches around the inside of the eye mount
Summer Fun
Banned
That's not considered a big boat !!. Its a boat that is trailer all the time and most all came with them. :).
Why yours didn't come with one who knows ??. :confused:
This_lil_fishy
Those old Chris's are HEAVY. If you do put an eye in there, put lots of structure under it. Dunno if I'd trust a an 8" plate, I'd make it bigger if I could. Around here, they just sling lift them out onto the trailers....
Ian
Naw, Not the anchor Line, but where it dead-ends at the bow, in the locker...
My hull has a 3/4" plywood stringer that deadends there..
I slid an aluminum pipe through the hole there(where the anchor line ties),+ ran the U-bolt through it...
Sorry, but no picture of it..
You could probably bend an aluminum plate to do the same in your bow..
MaverickGrabber
Ian
was thinking 8" all the way around ....would be 16" round plate
MaverickGrabber
boat dry is 6400 lbs ......not going to winch it onto the trailer just use as hold down
smokeonthewater
I have been doing some research into this very thing for my 28'er I had planned on forming a 3/8 plate and having it galvanized but after a bunch of reading I am going to do it with glass and wood..... you first wipe down wash and then grind the inside of the hull till it is free of all grime paint and gelcoat.... then cut a square hardwood block or heavy marine ply and perfectly fit to the hull you will fill the triangular void behind it with resin soaked glass ans glass over it to hold it in place.... then drill and back with a stainless plate.... you could pretty much lift the boat with a helicopter if done this way..... the brace being glassed to the hull is much stronger than the formed metal plate I had first planned
