LOLOriginally posted by roscoe:<br />Since you can buy a new dryer for $600, this is really a non issue. Throw it away and buy a new one.<br /><br />Sorry Heinz, only kidding, just got carried away after reading your dvd post.
<br /><br />I don't know about your dryer, but in several I have worked on, the drum rides on a couple of rubber wheels, which have a steel bushing inside. They are supported on a shaft. They wear and squeek. I have applied graphite to the shafts and they got quiet.<br /><br />Typically, you start disassembly by removing the front panel, and keep going till you get to the parts you are after. Good Luck.
Yeah had to make sure washer was level too so wouldnt shake, its been level forever but Ill recheck, thanksOriginally posted by mellowyellow:<br />also make sure it's level...
yeah aint it the truth, ya go thru spurts where everything works and then BLAMMO, alls your doing is fixin stuff on weekends!Originally posted by mattttt25:<br />heinz- man, you're on a roll! fixing the whole house! before you even pull out any tools, pull the dryer away from the wall and vacuum/clean out the back/insides. i had the same problem about 6 months ago, and was surprised to find so much lint/dust/crap/socks. when i cleaned it up, the squeaking went away without touching any of the parts. good luck-
