Re: OK to run viking outboard out of water?
Depends. Some have water pumps, some do not. Those with water pumps should NEVER be run out of the water. The others can be run for a few minutes, but the exhaust tube will get stinking hot. That heat travels upward to the powerhead and overheats it too---just as if it were sitting on a hot stove.
Look for a forward-pointing tube just aft of the propeller. If it has one of those (ram tubes), it does not have a water pump. BUT it depends on prop wash and forward motion through the water in order to operate.
Short answer---don't run it out of the water (and on a boat--with propeller) and you won't have any trouble
