Joshua Nichols
- Joined
- Jun 29, 2009
- 1,431
I had to replace some old wore out manifolds on my tub.. Oil is milky..
Anyhow got the new ones on.. They are perfect(way to go Osco)..Warmed the engine up so I could pump out the oil... Got it all out of there, even spun over the engine to get the crap from the pump to the filter.. After adding oil and checking with the dip stick still got milky oil. No it's not a cracked block
.. This was before I even started the engine.. I was kinda expecting this.. So whats the key to getting pretty oil again? Change it a bunch? I was thinking maybe I could run some chemtool in it for the next change and see if that helps get the milky stuff out..
Hoping for a good remedy. I know someone has a good trick out there
