old 2 stroke oil question
rebars1
I have six 1 pint sealed cans of Johnson 2stroke engine oil that came with a boat I bought from my FIL. They look new, but I'm sure they are at least twelve years old. Are they still OK to use?
imstillatwork
Re: old 2 stroke oil question
I've got a few of those too...probably about 2-3 years on mine, sealed.
rwise
might do better to "ebay" the 12 year old stuff, though I don't think it spoils.
Major Woods
As long as it is sealed it is good to use. No shelf life on the oil.
seahorse5
Do the cans say TC-W3 certified on them? IF not, do not use them, they may say TC-WII, and if so definitely do not use them.
ED21
Master Chief Petty Officer
I'v got some Gamefisher(Sears) oil from the '70's TC-W rated. Maybe I should take them to the Antiques Roadshow & get it appraised. ;)
dajohnson53
Originally posted by seahorse:<br /> Do the cans say TC-W3 certified on them? IF not, do not use them, they may say TC-WII, and if so definitely do not use them.
Two questions:<br /><br />I understand that TCW3 is an improvement over TCW2. But (1st) is it such a huge difference that TCW2 oil would actually be harmful to a modern (not DFI) 2 stroke outboard that is intended to run on TCW3 - or is more a matter that it just isn't quite as good (for instance at preventing carbon build up) and running 6 pints through it is no big deal. After all, we're not talking 30 wt. here nor are we talking regular, long term usage. (Follow up question 1-b): Would any ill effects be reduced or eliminated by adding a dose of de-carb (e.g. Seafoam or other) to each tank?<br /><br />And (2nd) wouldn't an engine of the same vintage be designed for that oil, thus making it OK to use anyway? Also see question 1-b. :) <br /><br />Just asking the questions, not arguing.<br /><br />All that said, my first thought for original poster was: remember that 6 pts. represents about $10-$15 replacement cost with brand spankin' new Johnnyrude TCW3 at the ridiculously high dealer price - half that if you buy a different brand of (probably) equally as good TCW3 certified oil. So it's not worth messing with if you're at all concerned.
CATransplant
Well, my '58 Johnson called for 30 weight motor oil when it was new. Now...I wouldn't use that in it today, but I might go ahead and use that older TCW-2 stuff in it.<br /><br />At 24:1, there's plenty of oil in there to make it all OK. OTOH, I sure wouldn't put it in a brand new outboard. That wouldn't be prudent.
rebars1
Thanks for the responses. The cans say TC-W for 50:1 mix. <br /><br />The engine is the same as CATransplant's (Johnson RDS-20 35hp). Recently resurrected after about a ten year sleep.<br /><br />I've been using 50:1 with West Marine's 2 stoke oil. Should I be using a different ratio?<br /><br />I have not used the old cans yet, but it sounds like it would be OK.
itstippy
There was a long string on old oil a while back. The majority agreed that oil doesn't go bad like gas does because it's not volatile, but if it looks or smells funny then don't use it. A few were of the opinion that oil is cheap and outboards are expensive so why use old oil? <br />If CATransplant says use 24:01 in the RDS20 then do that. Anything he says about that motor is good advice; he's in love with it.
rebars1
It helps to read the fine print on the engine cowel door, which says to use 1 qt per 6 gallons (24:1) <br /><br />Thanks for setting me straight!
CATransplant
itstippy,<br /><br />Ha! In love? Well, I sure do like my outboard, but I don't want to marry it. :D <br /><br />Frankly, I don't see anything wrong with using that old oil in an RDS-20, as long as the oil doesn't appear to have deteriorated. It's better than was originally specified.<br /><br />But...I would not run any of the pre-1965 Big Twins on 50:1. Some might disagree, but I see no benefit coming from using a leaner ratio than the factory recommends. You might save a buck or two, but who cares? That 35hp outboard sucks up so much fuel that the price of gas is more of a factor.<br /><br />I'm using an old Evinrude "Cruise-a-Day_ 6-gallon tank on mine. That is purely a joke. Half a day is more like it, and that's if you spend most of your time trolling.<br /><br />If one of these outboards is new to someone, I recommend monitoring fuel usage closely the first few trips out. If you do much WOT running or even 75% of WOT running, that 6 gal. goes really, really fast. Fuel economy is not one of the RD series' long suits.<br /><br />I carry another 6 gal. tank in my tow vehicle...just in case I need it.<br /><br />Still...they're great engines. ;)
DHPMARINE
I'd never use OLD oil that was out of spec,in a position that needs to meet newer specs.But you can use the oil for lubing other things.Sometimes I want to heat a bearing so it fits over a shaft easier.That oil works.Sometimes I am starting a rebuilt motor and want to squirt extra oil into the carbs on start up.That oil works.<br />But as the sole (main) oil for today's motors,don't substitute.<br /><br />DHP
rebars1
It's not worth it to me to risk using the old oil in the fuel mixture, especially when I just got this thing working again. I'll just take the old oil to the recycling center and stick with the new stuff.
