cedarjunki
Thread starter- Joined
- Aug 23, 2007
- 472
what will cause it to flood only above 3/4 throttle? at idle or low rpms its fine, but if i run it at all over 3/4 throttle gas start pouring out of the carb...
carb is spotless! i thought maybe the float adjustment was out but i tried many diff angles and same problem.
if i hold it wide open, sometimes it will run a few seconds fine then flood/bog then pick back up and clear out..
