1 Johnny Jay
Thread starter- Joined
- Apr 16, 2012
- 17
When I purchased my boat it had a 19 gal stainless steel tank and a 12 gal plastic tank. I found a 20 gal tank under each gunnel hiding behind plywood. Called the previous owner, he said they weren't in use when he brought the boat 5 years ago( he didn't even know they were on the boat). He advised me not to try to use them. He said there was probably a good reason that they were taken out of commission and if I used them it would put a lot of trash in the engine. They seem to be original
equip.
Set up when I brought boat, 12 gal not shown (also in fore ground - area where orig tank was)
My plan; have them pressure tested (I filled both with water and let them sit for 4 days, no water leaked out). - powerwash them inside and out - install all new hoses - install a 10 micron water/fuel seperater - install fuel shut off switch -change the float & gasket - run new wires to new gauges (for some reason there is only 1 gauge).
Is there any thing I forgot or a good reason why I shouldn't use them? They would free up a lot of fishing space.
one of the orig tanks
___________________________________
1973 WELLCRAFT - 1985 YAMI 150 PRO V
equip.
