Old boat but new to me...
Bama7474
Hello to all,
I just purchased a 1990 Astro Quickfire 18FS with a Mercury BlackMax 150 XR4 outboard. Mostly the boat appears to be in good condition. Putting it in the water this weekend. Had a few questions regarding the trailer. The trailer is the original Astro trailer that came with this combo boat package. The wheel bearing caps are missing and there appears to be plenty of grease packed in there. Does anyone know where I could find new caps for these wheels bearings. The wheel bearings appear to be snug with no wiggle room but I did not know if submerging it would be an issue though there is plenty of grease in there to keep the bearings from rusting...I believe.
This is my first boat and have gained a lot of knowledge from reading these posts. I have been wanting to get a boat for quite some time but life was too busy to make that decision, I thought. I've removed everything that can be easily removed to clean it. It was left outside and had a lot of dry rot on the gunwale cushions and especially the carpets. Seats just had lots of mildew on them, nothing a power washer and some cleaner could not make look new again. I have found that all of my console breakers are bad and a few switches need to be replaced. I would like to know what some of the switches control. From left to right there is the Master switch (understood), Nav/Anc (understood), Bildge (understood), Acc/Curtesy (Not understood). If anyone can tell me what this last switch does that would be awesome. As far as I know I do not have any curtesy lights, if that is what it does, but there is a stereo that needs to be replaced and might be connected to the Acc.
I look forward to posting future posts
you need to identify the manufacturer of the hubs. maybe swing by a local trailer store.
also, with any new to you boat. do all the maintenance prior to splashing. new water pump, new plugs, gear oil change, trailer service, etc. in addition to your list of other issues.
the ACC/Courtesy switch would control either an accessory or courtesy lights (depending what was wired to it).
sportsman47
May I suggest measuring the inside of the hub, where the caps go, and get Bearing Buddies, or something similar. It is my opinion that the cost far outweighs the problems you may encounter with water contamination.
