CaneCutter79
- Joined
- May 24, 2009
- 454
I have a 1979 Cane Cutter modified tri-hull style boat. (see photo)
The current prop is a 19-pitch three blade OMC factory steel prop. I have a 17-pitch vented aluminum prop that has a bit more bow lift but not much and I loose about 3-4mph but gain a slight increase on RPMS. INCREADIBLE hole shot. I'm on plane in seconds with the small prop.
What I'm looking for is more bow lift and increased top-end WOT speed. The current speed is 39-40mph (GPS) and the motor is a 1979 85hp Evinrude V4.
My current problem is the boat runs almost level. It feels like there is too much bow and hull still left in the water at WOT. The motor will not trim up to where the cowling is at least level or higher than level without slipping. The motor sounds like its exhaust is cavitating and the mph drops from 39-35mph. Trim the motor back down and the cavitation noise goes away and the boat surges back up to 38 and then 39mph.
Also, if you leave the trim setting at maximum trim, slow to about half throttle and then hammer the throttle, the boat will rise (normal due to trim) and just before it get's back on plane the prop slips completely and cavitates. The RPMs go really high and it totally looses grip. I've also noticed that the motor has NO rooster tail. Is that a characteristic of an older boat hull? I thought it would at least have a rooster tail no higher than the cowling. I have none. Is that OK?
I do not know exactly what RPMs I'm turning but based on online videos I have seen of the same motor, everyone else is running around the 5,000 RPM range and so am I. It's not a really high pitched RPM range and it almost sounds like I have at least 300-400 RPM remaining to turn.
Do I need to swap to a 4-blade 16-pitch with a lot of rake to lift the bow more or swap to a 17-pitch 3-blade with lots of rake to lift the bow?
