Old carpet glue
croSSed
After you pull up your carpet, how do you remove the old, hardened glue that sticks to the hull?
TG
Re: Old carpet glue
A 4,1/2" Grinder with a Cup Wirebrush mounted on it,.........
It Peels the stuff Right Off........
tashasdaddy
Re: Old carpet glue
and safety glasses, mask, shop vac. and real old clothes. change in the garage before going into the house if you know whats good for you.
dadgummit
Re: Old carpet glue
I used about a 4" razor blade scraper from the flooring dept. at your local home improvement store. Works good just be careful not to gouge the surface.
Re: Old carpet glue
the PO used Liquid nails to hold down the old carpet. I was thinking of using the scraper like dadgum said
