old champian
unclebeaner
well i cannot seem to find a horsepower rating on it but here is the info i collected-
serial # 080506
plugs 5mj
carb tillson me2a
its a blue twin cyl with two blade prop. i want to try and find carb kit, points and condensor, updated plugs and wires. i think these old motors are starting to turn into a hobby with me everytime i see one now im buying it just to screw with.found this one walking into scrap yard it is in outstanding shape but has been sitting for some time. for the $5 i paid for it ill give it a whirl thansk for any and all help guys
F_R
Re: old champian
The Tillotson ME2A was used on the Champion model 4K Deluxe Lite Twin 7.9hp, 1948-50
It was also used on the model 4KS Hot Rod. You wouldn't be so lucky as to have found one of those for 5 bucks, would you?
You didn't hear me snicker when you said "carb kit" did you? Seriously, for what it is worth, the carb kit is part number 08417 and the carb gasket kit is #08415. The float valve is 08018. Tillotson numbers. Good luck.
You might want to check in over at the Antique Outboard Club, www.aomci.org
steelespike
Re: old champian
Need a model number something like 4K 4L etc.
57/58 was last Champions years of production.
Try the antique outboard motor club @ www.aomci.org
Point setting generally .018.Most models use 1/2 pt per gallon. TCW3 rated oil.
unclebeaner
Re: old champian
alright ill do some looking at motor when i get out side nothing on those point numbers? could i use a generic cap. like from lawn equipt?
steelespike
Re: old champian
"nothing on those point numbers?"What do you mean? I would check at the antique outboard mptor club on the capacitor.While a cap relacement is easy and inexpensive it is my experience they seldom fail.
unclebeaner
Re: old champian
one is split on this motor like it got crushed and i was asking on the points part number. thanks again i posted over at the board you mentioned earlier
