Old double fuel line how do I change it
trucker28
I have a 1956 7.5 HP johnson with the old double fuel line can I change that to the single fuel lines.
wilde1j
Re: Old double fuel line how do I change it
You need to install a fuel pump first.
lindy46
Sure - just get the same size single line and tape them together with electrical tape. I did that on the tank for my "57 Lark and it works fine. As long as you don't get gas on the tape (it will dissolve the adhesive). Just leave about 6 inches untaped on the ends.
ezeke
The dual line hose is sold by BRP authorized dealers as part #0772566 - order by the foot.
If you use the search function and "pressure tank conversion", you should find some discussion.
Mas
I think the question is to convert from double line to single line. You'll have to find a fuel pump small enough to mount to one of the bypass covers and drill through a "centered boss" and still have mounting screw bosses. I do not know which pump will work for your motor.
Mas
