- Joined
- Jul 18, 2011
- 19,570
Hi Folks,
My outboards have been tag-teaming me the past week or so . . .
I recently resurrected my 1969 Mercury 7.5 HP to use on my dinghy, having replaced the water pump and doing a carburetor clean. It ran well but the swivel bracket keeps stiffening up . . . after a bit of usage it seems to free-up a bit so that I can at least steer.
Well after leaving the dinghy (with motor attached/tilted up) for a couple of weeks the steering was more than stiff . . . it would not budge no matter what. I assume the salt water is raising havoc with the steering swivel and binding it up. This has happened in the past, but I have always managed to get enough grease pumped into the swivel that it frees up with some work.
This time it would not move and after several days of working on it, soaking oil into it, heating it, soaking it in rust solvent, applying a power wash (2500 psi) to the exposed swivel joints, etc. . . . It finally wanted to move ever so slightly and now moves with some force required (I removed the steering tensioner pads first thing).
I assume that if I work the thing into submission by working the tiller back and forth it will be OK for a while, but then will 'freeze' up at the next use.
Meanwhile . . . I took my Yamaha 3 HP motor down to the dinghy dock and mounted that up to use while the Merc is 'in the shop' . . . The Yammy worked for a brief while and then crapped out . . . won't re-start for nothing.
:facepalm:
Thinking to myself, I'm running out of small outboards,
I take the Yammy back home and try to sort that out.
Back to the Merc . . . I'm thinking that I should try to fix the swivel for good so that I can use the motor in the salt water without having to fuss with the steering each time I use it. I've already 'upgraded' the drive shaft on this motor to the stainless steel version for salt water use, so perhaps the steering/swivel assembly is next.
I can get the steering assembly taken apart to about this level, but the swivel pin does not seem to want to come out . . .
My plan would be to buy a piece of stainless steel tube and fabricate it to replace the carbon steel tube (swivel pin) that is currently in there, but I just wanted to toss this issue out there to see if there is a better approach :noidea:
I was also thinking of using a thick wall PVC tube instead of metal, since the engine is only 7 HP . . .
I could also buy a used swivel assembly on eBay ($150 ish), if all else failed :noidea: However, I bet I would have take that one apart and make it salt water compatible as well . . . so who knows how that approach would work out :noidea:
TIA for any thoughts . . .
PS - Normally, I would just go with the much newer Yammy, but it is only 3 HP and a single cylinder . . . which makes for poor idling, I prefer a 2 cylinder motor over this single cylinder Yammy. My only other OB is a 4.5 HP Johnson long shaft, which is no good for a dinghy . . .
