Re: Old Fuel
I spent 3 months and big $ getting bad fuel out of my entire system - tank [drained], pickup [replaced], vents [cleaned], sender [cleaned], lines [replaced, all - even internal to the engine], VRO [replaced], all 6 carbs [cleaned and cleaned and cleaned again], the kicker [repeat above]...<br /><br />I added a stabilizer mid winter to fuel that already had water, add some spider webs = bad news. It turned to a white jelly that hardened like silicone rubber throughout the system. Every time the shop thought they had the problem licked, more of it broke loose and caused problems. It took an OMC rep and advice from this forum to isolate the problem. see post August 28,2001 - Jellied fuel.<br /><br />This was my experience - didn't save any $ by trying to use that old fuel. <br /><br />good luck,<br /><br />Cliff
