ronboonville
Thread starter- Joined
- Jun 6, 2012
- 287
I tested the resistance on the coils awhile back and they checked good. but still lower cylinder had no fire. swapped coils from one side to other and still had no spark on lower cylinder. installed new points and cond. and everything was good. ran good in barrel. started yesterday and sounded like it was running on 1 cylinder. took it to the water anyway thinking it would get better, not. would not engage reverse so I beached the boat and looked at linkage, bracket was loose, then fell into lake. okay, no problem, had old trolling motor and battery for back-up. headed for ramp now and halfway across small lake noticed I was taking on water! lots of water! made it though with about 2 inches of water line at back of boat. Oh and bilge pump had come apart. Are we having fun yet? drained about a jillion gallons out. found problem with bilge pump and found the live well drain hose was broken. Okay water problem solved. so, back to my question can coils look good and test good be bad? can heat affect them? only 106 degrees here. engine was cool enough to put hand on flywheel. this is a 1960 gale 35hp. similar to a lark or big twin. will pull flywheel and check points today but was thinking about buying new coils, hate to because of cost. but havin fun ain't cheap. any feedback appreciated, thanks, ron
