78whiteorbs
Thread starter- Joined
- Nov 13, 2008
- 138
ok, got this 69' 33 horse electric start that wants to run. Went through the ignition system under the flywheel ,all is good , has good hot blue spark both cylinders. Replaced fuel line, hooked it up to check for leaks and it is not leaking but after priming the bulb all the way if it sits for a minute or so the fuel retreats in the fuel line some(I know cause it's clear fuel line)I hook it up to the battery turn the key and it wants to start. backfires a bit but when I release the key it gives up.I haven'tcleaned the carb yet (Iknow,Iknow) that was my next step. I was thinking though that even just spraying some fuel mix in there it'd run for a little bit , but it doesnt. just tries.
One thing I noticed was that two bolts where the starter mounts to the bottom are missing and smoke is coming out of these holes a little bit. Desperately trying to get this baby running. There is a filter on this engine but I dont see a fuel pump behind it...
