Old jon boat transom
muddigger737
Hi, i have a older 14 foot jonn boat and i was looking to replace the transom since its getting a little weak. I was wanting to cut the old one out and have a welder weld a new one in, but i do not know what kind or thickness of aluminum to use. If someone could give me some help on what kind and thickness of aluminum to use it would be great.
Re: Old jon boat transom
Ayuh,... What's so Bad with your's,..?? I can't feature doin' it that way,..??
muddigger737
There is no wood in it it is just a piece of aluminum and i have a 9.9 motor mounted on it and when i put it in reverse the transom moves and i would either like to replace it or reinforce it with wood. What would be the best thing to do for it.
Ayuh,... I vote for Reinforcing with wood or aluminum or whatever ya want...
Cutting it apart would create Much more work...
muddigger737
I will probabaly end up reinforcing with two pieces of wood and how would you propose that i attach the new peices of wood to the old transom.
lckstckn2smknbrls
Are there handles on the transom? Are there any holes where handles were?
Is there a knee brace going from the floor to the transom? These would be the bolts used to mount the transom wood.
Do you have any pictures of the boat you can post?
I don't know how many jon boat transom replacement threads are on Iboat but you can look on www.tinboats.net for lots of info on this type of repair.
avimgod
I would either glass in a new transom wall with wood core, or make another transom wall and fill between the 2 aluminum pieces with seacast..
Either would work, but will also add weight to the transom... if you weigh your materials going in, add the same amount of weight forward to re-balance the boat... 14 foot tinny can't be all that heavy to begin with so you will want to be careful as any weight added will take away from the capacity of the boat!
muddigger737
There are no handles that are mounted to the transom, they are mounted on the corner braces and there is a knee brace from the floor to the transom but it is rivited. Would it hurt it if i drilled a couple holes and sealed them up good. And is there andy way of attaching the wood to the bottom of the boat or not? Thanks
lckstckn2smknbrls
Does it look like there was ever any wood for the transom? Is the knee brace riveted to the transom with space for some wood or is it tight to the aluminum. The original transom may have been a narrow piece of wood that went across the transom above the knee brace. You could build something to fit in this space and bolt it in with stainless steel bolts.
jspano
pictures are worth a thousand words... post them!!!!!
do not cut any orginal alum!!!!!
re-inforce with wood(not pressure treated) or alum, inside would be my choice if possible. i would try to use some alum angle to make a channel on the sides. attaching the angle and the new pc. to the transom with stainless steel nuts and bolts and the the angle to the sides. don't froget to use 3m 4200 to seal all
muddigger737
I cant post any pictures at the moment because i have a broken leg and cant get to where im storing it with my leg being the way it is. but i dont believe that there was ever any wood on the transom and the knee brace is rivited tight to the transom. Also it wont hurt it if i drill into the bottom and seal it up real good. Thanks
muddigger737
Oh and one more thing what will be the best type of wood to use and the best epoxy to use and anything else i will need. Thanks
jspano
i would not do that. take a look at how some larger boats have the wood attached
see the tray on the bottom of the wood and on the sides
[/IMG]
this pic is borrowed from a friend
high quality exterior ply wood, poly resin and fiberglass if you want to go that route, 3m 4200 for sealant
muddigger737
My boat does not have trays like that but if i fabricated some, what would be a good way to attach one of them to the floor of the boat.
jspano
the sides are easy thier just angle brackets. the botom pc is more like a Z shape
lckstckn2smknbrls
You will want "NON" Pressure treaded plywood about 1" to 1.5" thick. As big as you can fit in place. You can paint it, varnish it or coat it in epoxy resin. Then bolt it in with stainless steel hardware. You can also put some plywood on the outside of the transom. With enough bolts this should be strong enough for a 15 to 20HP motor.
Go to the tin boats web site you will dozens of transom rebuilds.
muddigger737
I know that the wood does not go on the floor, i was talkking about how to attach a piece of angle like the tray on the bottom of the boat you posted and what would be they best way to attach something like that onto the floor of my boat.
jspano
there are plenty of transom rebuild right here look at any alum restore on Iboats.
i already stated not to use pt wood and advised not going all the to the deck. this will not interfere with any drain plugs and advoid drilling thru the deck/hull. all fasteners will be in the transom and port and starboard side walls
