Re: old small Eska help
The Tecumseh V51 motor is used on 61-67 motors 3hp,4hp,and 5hp
The 4 appears in 61-65.
The Tecumseh section of my after market manual covers timing.
Is there no timing section in your manual?
Directions are a little un clear but basically those without a governor
Rotate the stator fully clockwise and tighten the 2 clamp screws.
There is a more involved procedure for those with a Governor.
And there is a Sync procedure in the Tecumseh fuel system section.
If you need the governor equipped timing I'll be glad to post it.
I have an Abos 6th edition,volume 1 aftermarke manual, covering many brands,that covers 65-72 Eskas and Tecumseh, a Abos 4th edition volume 1 covers 61-67 .You may find one at the library.
