Older Eagle Fishfinder problem
muskrat808
Hi I've got an Eagle Ultra Classic Plus(?) about a 1995 version came with boat I recently bought . Speed, Temp , Distance , Voltage readings all work but Depth always reads 0.0 . Bad transducer ? Can it be tested? Is it worth replacing or just buy a new cheap unit ? Use in fresh water I dont need or want anything fancy so if this can be repaired cheaply it would be fine . Thanks
Low dsrt jon
Re: Older Eagle Fishfinder problem
Bad transducer? If everything else works I would think so. You can get one from Cabeles even for a 95 they still sell them for about 50.00 . I use the same unit for my bow mount on my trolling motor and it works great. LDJ :):):)
