older merc 4hp reads 40 on the sticker
rick101
I have some LU issues, the prop shaft seal is leaking a lot and the bearing carrier will not move, can someone please provide me with the proper instructions for removal, also it leaks most likely from every other seal as well.
I have replaced the o-ring around the water pump housing and the oil seal under the lower housing but it still leaks, I suppose the drive shaft might be to rusted for a proper seal from what I have been told. But in my opinion the shaft around the water pump doesn't look as bad.
Where would be a great place to get a complete water pump kit plus all LU seals to assist me in this issue?
Or would it be better to find a parts motor?
Cheers,
Rick
