CaneCutter79
Thread starter- Joined
- May 24, 2009
- 454
Here's something I ran across after reading up on the the ethanol in outboard motor issue. Newer sythetic oils are thinner but coat better than oils back in the 70's & 80's. Some folks are going from 50:1 ratio to 100:1 because the oil smokes less and reduces cabon/oil build-up in older motors. One guy had been running his older Evinrude motor (115hp I believe) for 3yrs this way with superb results after a rebuild.
I have had my 79 model Evinrude for 2yrs now and did not know I needed to protect the motor from ethanol fuel and now I need a rebuild because one cylinder has low compression. I always use at least 87 octane fuel and sometimes I've tried 93 octane with better mileage results. I assume ethanol in the fuel may have contributed to the leaking gasket I have and now bad piston ring. Now that I know better now, I will protect against in the future with fuel treatment.
So has there been much disussion or experience with using newer synthetic outboard oils in older motors? And is it safe to reduce oil to a 100:1 mix? I'm thinking NEVER EVER reduce but wanted to ask around.
Here is the oil I was looking into...
http://www.amsoil.com/storefront/ato.aspx
