Travis.Bernard
Thread starter- Joined
- Apr 11, 2017
- 15
I have an older omc fuel tank and it has like five prongs on it does it take a certain hook or just the basic hook up? New to boating any help would be great
I don't know how easy it is to change connectors, but in theory - unless the tank is pressurized, the tank itself should work. Changes are you can find one on eBay nearly as cheap as you can make one (at least I would think).I guess my biggest question is you can use any fuel talk for any engine just have to change connectors.
I just grabbed that image from another topic. That was where a member was having a leak. The OMCs connected to all of those points.And southkogs it leaks from the connector you pointed at? Is that a vent or does it hook up
The old original tanks used 2 fuel lines molded together as a pair. One was for fuel and the other for air pressure. You used to pump up the tank because the early outboards didn't have a fuel pump. Back when the tank was part of the engine gravity was your pump. Before redesigning the larger engines with pumps they just used your thumb as the pump and pressurized the tank forcing the fuel up and into the carb. No reason you would have to use the air pressure line. It would just function as a vent for the tank. As 123 said, get you a couple of hose barb to hose barb to hose barb connectors and make your own.
That's a standard single hose Mercury male fitting. My previous comments will work.
So is the one I got pressurized?
Those tanks also typically had the hose (a siamese hose, shaped like an "8") permanently attached to the tank. A quick connect only at the outboard.
If the OP wants to use the old style 6 gallon metal tank, he can just change out the connector on the OMC type hose setup for his engine and happy boating. The tank doesn't care what type engine it is feeding. And those old metal tanks are very nice and convient to use and carry as well. JMHO
