artificialreef
Thread starter- Joined
- Feb 21, 2009
- 504
I just bought a beat yami 92 waveiii (wra650)for 250$. It had starter bolts broken off in the block that I drilled out with diamond bits and an angle dremel. (in about 4 weekends, so I didnt have to pull the motor) I put a new oil pump/lines and check valves in and am not comfortable with the amount of oil going into the carb. I can dig an oil pump block off plate but doesnt the pump deliver more oil when its necessary thus changeing the mixture. This oil pump is not electronically controlled. Runs off the crank I guess. Any opinions. Thank you.
