Omc 115 Turbojet stripped down and starting the rebuild
Abomb27
I have a 1996 Omc 115 turbojet, that I am going to rebuild. It is fully disassembled, and I just dropped it off to the machine shop. They are going to check the bore, and hot dip the block to clean it up. BUT they told me they cant bore it if it needs it. Hopefully it doesnt need it. I want to post my progress. First motor I am rebuilding, I find it interesting, hopefully I can het dome advice about things people have learned while doing theres. Im sure I will have questions along the way. And boobie if you read this I talked to you awhile ago about this motor missing a ring on 1 cylinder. There was almost no damage anywhere. The guy at the machine shop said all the walls looked good. One cylinder had some scratches that he said he couldnt totally get out with a hone. But not anything to worry about he said. I believe it wasnt put on, dont know what else to think. He said if a ring went the walls would be toast.
Honorary Supreme Mariner
Re: Omc 115 Turbojet stripped down and starting the rebuild
Any damage to that piston ring groove ??--------Any pictures of that ring groove.----Fairly common for those to have a broken top ring that gets spit out the exhaust.---What does that marginal cylinder measure at now ?--Pictures of the score marks ?
Abomb27
I have to figure out how to post pics. There is some scratches on the side of that piston. Doesnt look that bad I dont think.
I have seen many of these V-4 motors with broken rings.----Do my own boring and honing.----Nothing to it.------------Does not look bad is not the same as measuring the bore accurately.
Abomb27
I have a micrometer to measure the pistons, but could not find one to measure the inside of the cylinder wall. Thats y I dropped it off. I gave them the bore size, and they are going to check it. I agree I dont want to take any shortcuts.
Abomb27
I checked that piston again and it is scratched up on the one side and some damage in the same area on the ring groove. And it is the upper ring. My pics wont upload. I dont know why.
You need to find / determine what went wrong here to make sure you do not have to do the job again soon.----Often these jet boats lead a tough on the throttle / off the throttle type life.----Post the measurements of the 4 pistons measured at the bottom of the piston skirt.--That ring was there and was spit out of the engine.
boobie
Without seeing the piston, I'd say you're better of replacing it if you want to do it up right.
Abomb27
Got pics. Had to lower the image quality on my phone.
Abomb27
This boat was abused by previous owner and minimal care and maintenence was done to it. It had a lean condition, that I fixed last season. Ran well, im tebuilfing because I want it to be perfect, and have piece of mind.
fishman204
Just the read I was looking for.I'm a little gunshy to do mine so I hope you keep posting.Hope all goes well
Abomb27
I love the boat and it ran well. Im just hoping I can get it perfect. The more I took it apart, the better I felt about being able to get it back together. Plus im in pretty deep now, so I guess no turning back. Lol.
Abomb27
I measured the pistons and here are the numbers in inches. Piston 1) 3.489, 3.493 2) 3.492, 3.488 3) 3.493, 3.487 4) 3.493, 3.488 I measured in two spots. My manual says 3.4930-3.4950 in. I am going to replace all the pistons. I figure it would be a good idea. Do those measurments tell me anything. Pistons a little worn out?
Well the one that had the missing ring is scrap and the measurements on the others indicate they are worth about 50 cents / lb ---Scrap------Let me think how many times I have seen this damage.---------It needs boring / honing and 4 new O/S pistons fitted.
Abomb27
Any idea why the machine shop told me they couldnt bore thst kind of block. I guess I have to find a marine machine shop somewhere.
boobie
If any of the other pistons look like the pic you posted, replace them all. How do the cylinders check out measurement wise ?? If they're okay you might get by with a hone job.
Abomb27
There at the machine shop. He said he will have it for me on monday. So I will post his findings.
I guess they do not have the correct boring bar, nor the proper honing tools to do what is essentially a " blind hole "----Contact your local marina people to find out where they send theirs.-There are fewer and fewer shops that do this sort of work !
Abomb27
Is it a good idea or bad idea to pay extra for the Wiseco forged pistons?
boobie
I like the original BRP. JMHO but there are a lot of opinions out there about them.
