OMC 115 V4 crossfiring ignition.
drackley
Sigh. I started this rebuild in February and am still throwing time and money at getting it to run right.<br /><br />Marked flywheel for all cylinder positions. Hooked timing light to individual plug wires trying to determin miss and backfire. #1 ok, #3 shows crosstalk with #1, #2 shows number 4 mark, and #4 shows number 4 mark. Plugs, wires, power pack, timer base, coils are all new. Any advise folks?
Dhadley
Re: OMC 115 V4 crossfiring ignition.
Which 115 do you have? Model number please!
drackley
That light bulb went on about a half our later ;) <br /><br />1994 Turbojet 115JEER. 115 hp evinrude V4 crossflow CD4 ignition
drackley
Additional info: Timing light on #1 firing on 1 and 3. Timing light on 3 firing 1 and 3. Timing light on 2 firing 4. Timing light on 4 firing 4. I've just compleeted ALL diagnostic tests in my factory manual of stator, timer base, power pack, and coils other than the high output of the coils, and EVERYTHING is better than spec. I'm lost :confused:
OBJ
Drackley....check the the ignition coil wires from the power packs. Simple code here, Blue Skies, Green Grass. Make sure the pack wires are blue stripe to the upper coil and green stripe to the lower coil. One or the other will have a stripe on it.
drackley
Those are fine, and a reversal I don't think would cause these simptoms. I have no #2, #4 is firing on 2 and 4, and 1 3 are double firing on those two cylinders.
marinegrh
just a dumb thought on my part, but do you have maybe a bad flywheel key, i know it sounds stupid, by maybe
marinegrh
post your test results please of the ignition system, ie timer base and pack voltages, shorts to ground and resistances
drackley
I would have to run all the tests again to do that. As noted above, they are all better than minimums, and no shorts. Hence the query as to what might be up since it makes little sense. A loose/moved flywheel would cause the timing to shift in most cases, not the noted lose of #2 and double fire of 1 and 3.
