SeanMcl
Thread starter- Joined
- Apr 3, 2009
- 187
I'm pretty ignorant about ignition systems, so if anyone has experience in this, I'd appreciate a whack from the clue stick.
I've got a 1974 Gulfstream with a OMC 190 Sterndrive, Ford 302 motor. It has a Prestolite distributor in it, and since they are out of business I can't get new parts for it. It needs at least a new cap and rotor, I did not get down into the points.
I'd like to replace it with a new points-less distributor, and Mallory makes a marine unit that looks like a drop in replacement, number YLM512CV. I would replace the coil and plug wires at the same time.
3 Questions.
1. Are there any more parts I need to make the swap, are is the new distributor, coil and plugs enough?
2. How do I adjust the timing and advance, or do I not need to do that anymore?
3. Will my old tach still work? The manual hasn't much to say about it.
Thanks in advance for your help.
3 Questions.
