Bulbash
Thread starter- Joined
- May 22, 2012
- 332
My carburetor butterfly valve on the throttle gets stuck open. If I fully open it with a finger and let it go it has enough spring force to close itself, however if you release it slowly it gets stuck at the last moment. If you use a throttle control you cannot make it go in closed position. I tried lubricating all moving parts there, but no luck.
On the first picture I circled some kind of a controller, I'm not sure what it does, but it feels like it has some resistance that might cause the issue.
Second picture shows the position of the stuck butterfly valve.
