omc 2.3 running rough
brett7721
i have a 1990 four winns it was running great on the muffs and the all the sudden it started to run like **** and now its only running cylinder 2 and 3 and the spark looks when i pull the plug wires what can it be
Bt Doctur
Re: omc 2.3 running rough
pull the plugs and see if any water comes out the holes
brett7721
pulled the plugs and and thay were black and the compression was 120 cold on cylinder 1 and 135 on cylinder 4.does any body no the fireing order on the block and the cap.
brett7721
ok checked them and there right i have a wire back by the starter solenoid that is gray with a black strip and dont no where it goes. it was a friends boat and got it cheap trying to get it going.how can i tell if i have a mallory or Prestolite Distributor.
danond
A factory (not Clymer, not SELOC) service manual will help here. You can get them on eBay. They have color wiring diagrams in them.
Sounds like you need to do a basic maintenance run-through before you go much further. Replace cap, rotor, points, set the dwell, gap, r&r plugs, check/replace plug wires, see if the carb needs a rebuild, clean the battery and starter connections, drain and refill the outdrive, inspect gimbal bearing, bellows, etc etc.
Taking on any used/old boat basically requires these things or you're going to be dead on the lake every other time out and dealing with issues like what you have here.
brett7721
I replaced the cap rotor points and set the dwel and plugs and wire that i got from a napa.but i was on a web sit that i found on a form and the distriabator that napa told me i have is a Prestolite but i found a pic of a mallory and mine looks like that so im wondering if its a matter of the wrong parts or a loose wire or a wire off or something stupid be for i did the points and condenser it ran great then it started to run on 2 cylinders
