omc 2.5 battery hooked backwards!!
Status
Not open for further replies.
pizzafellow
Hi all,
I did the dumb mistake of hooking the new battery backwards today !!
Wires got warm and when I straightened the battery cables there is no juice.
Why did I fry? a fuse? if so can anyone please tell me where to find the part that need to be replaced.
I appreciate any help I can get.
Thankyou
It's an omc 2.5 120 hp, 4 cylinder, 1985.
chiefalen
Re: omc 2.5 battery hooked backwards!!
There are 2 fuses in holders look like plugs. They are in the starboard side with a spring clip holding the fuses together.
You can get the fuse at radio shack.
Fishermark
There MAY also be a large "fuse" on the starter where the battery cable connects to the lug. It would look like a 1" square cube if one is used. You may or may not have one.
pizzafellow
Thankyou Cheifalen
I found the rubber plugs with the springs holding them together , when I unplugged them from each other there is nothing inside they both look just like plugs. I will need to run to the boat again to check for the 1" box.
I appreciate all your responses
Fishermark
The fuse I referred to is more common on Mercruiser engines I believe... but who knows what can find its way into boats and engines. ;) Here's what the fuse looks like that I am referring to:
bruceb58
After you figure out the fuse situation, check your alternator output with a volt meter to see if that got fried.
pizzafellow
Thankyou Fishermark,
The pic might be of great help but I will have to wait until morning to check it out, Tired of a long days work and it's getting dark outside. I will post my findings in the morning.
thnx again
pizzafellow
Will do Bruceb58,
I hope I didn't do a lot of damage. I'll do more work on it in the morning and post what happened after work..late afternoon.
chiefalen
Those plugs are for the esa.
Right below them are the plugs for the fuses.
They are held together with the same kind of clips and are thru a steel plate.
Please disconnect the battery before you install the fuse.
sundowner205
The fuses are rather large, should be 50amp, and most likely in a large yellow cylindrical fuse holder towards the back of the engine.
Also, be sure to check any other electronic device that was connected , such as the radio, etc. The reverse-polarity may have fried them.
Best of luck.
-Mark
chiefalen
There is no square fuse on the starter.
I have the same setup, to the year.
They are black the fuse holders.
The fuses are held together with same sort of clip that the esa plugs had.
And they go thru a steel plate.
Same plate holds the esa module.
Make sure the battery is disconnected, when you open up the fuse holders.
And when you go to buy new fuses bring the old one with you and buy extras to keep on the boat. You will need them.
Bye chance it's not the fuses, please post and i'll help you find what it is, not letting you get juice.
pizzafellow
I did find the fuses like you said chiefalen. One of them was blown, the other was good. I replaced both for about $3 from autozone. Didn't have a chance to check the voltage on the battery with the engine on yet, to check if the alternator got damaged. I will be doing that tomorrow as I also have to check the tilt mechanism. For which I will start another thread tomorrow. I also bought the Seloc book with reluctance... I'd have prefered the original factory book but I can't afford it now:(
thankyou all for the input.
chiefalen
You got the one says. 0mc Stern Drives 1964-86
#3400 in upper right hand corner.
If yes than i have that one if you have questions cause the book is far from complete.
I had every part, apart in my hands.
Maybe i can help if you need it just post.
pizzafellow
That's the same book I got Chiefalen. It could be a lot better!!
I am having problems with the tilt mechanism and I will post a new thread and hopefully you can help me with a few issues.
bpmcl00
the guy who had my boat beofre me reversed the battery cables. it ended up blowing the alternator, and a fuse in the dash that ran all accessories( blower,bilge,horn..etc) hope yours isnt as bad as this
good luck
pizzafellow
After I replaced the bad fuse The accessories work just fine but the engine now will not turn on. I teried a few times using starter fluid and cleaned the spark plug but it seems there is no spark. And the alternator felt a bit warm even if the engine never came on. So I dont know what else I fried if any..!!!
chiefalen
It cranks but won't start correct?
Take a spark plug out and have someone crank the motor while you ground the tip of the plug, see a spark?
If no than check your points first.
They welded together?
Test to see if you have juice at the coil, ill post a thread how to trouble shoot this.
http://forums.iboats.com/showthread.php?t=167035
chiefalen
The alternator take it to Auto zone they will test it for you. For nothing.
If bad you will need a marine one, no short cuts with a auto one. Same with the starter.
Capice?
pizzafellow
Yes the engine crancks but wont start. I will check for the spark as you said in a few days then post the results.
Status
