OMC 240 Inboard
CYJMI
seems I have messed up when I rebuilt my dashboard for this engine. When I turn the ignition and before I fire the starter I can hear a sort of scary click click in the electric parts of the engine. Any idea where I could find the elctric diagram for this engine 1972 8 cyl OMC 240 HP...
Backlash
Re: OMC 240 Inboard
Hey CY,<br />Does that engine use an electric fuel pump? <br />Backlash
Trent
Re: OMC 240 Inboard
Check ground connections on the engine from the battery.. Check battery connections and make sure battery has a full charge and is good..Try using jumper cables to another battery. Sounds like low voltage clicking of the starter solinoid.
CYJMI
Re: OMC 240 Inboard
thx for your answers but unfortunately , the battery is brand new, I don't think it's an electric fuel pump . You know when you turn the key you have a position when you have power but nothing is supposed to happen yet, it is when This noise I was talking about happens I repeat, before I try to fire the starter,
petryshyn
Re: OMC 240 Inboard
step 1<br /><br />>track the noise down to a component<br /><br />step 2<br /><br />>let us know which component
Trent
Re: OMC 240 Inboard
Sounds like you have somthing backwards..I will try to remember to look at work..<br /><br />Check this link out. I know it does not say OMC but its the standard for what boats are to be wired by.web page
CYJMI
Re: OMC 240 Inboard
you guys are great ...i'll drop by the boat in 2/3 days and check all that.I printed the PDF doc for the wiring. what are the chances that mercruiser and force instructions work for OMC, especially an old piece like mine ?
