Omc 3.0 140 hp
misiek
I have a 1985 ThunderCraft 3.0 140 HP OMC with a cracked block. Can anyone tell me if I can replace it with a 1976 3.0 OMC? I know that there is a slight gear ratio difference. Can it be corrected with replacing the fly wheel and coupler with the old parts from the bad engine I am replacing?
Bifflefan
Re: Omc 3.0 140 hp
The block doesn't have a gear ratio....the drive does.
Again, no gear ratio here either.
Howard Sterndrive
Re: Omc 3.0 140 hp
the long block engine itself will be identical
coupler and flywheel is the same 76 and 85
zbnutcase
Re: Omc 3.0 140 hp
As long as its not an early Cobra, some of which started to trickle out in late 85,then you will have to change coupler.
misiek
Re: Omc 3.0 140 hp
What is the earliest model of the GM block that will fit? I see the difference in the exhaust manifolds, carburetors but are the engines any different?
Re: Omc 3.0 140 hp
Ayuh,... All of the Blocks,... From the begining will fit...
It's everythingelse that's bolted to 'em that changes....
misiek
Re: Omc 3.0 140 hp
How can I identify which engine do I have? Please look at the photos and advise. Thank you.
Howard Sterndrive
Re: Omc 3.0 140 hp
the big "3 Litre" sticker kinda says it all, no?
(I always wondered why OMC wrote Litre instead of Liter
they tryin' to be all French?)
misiek
Re: Omc 3.0 140 hp
What I meant is it a pre 1986 block? Not a cobra, right?
misiek
Re: Omc 3.0 140 hp
Here are the pictures. I need to be sure that this is not a COBRA before I'll go engine shopping. Most of the late 70's and early 80's engines that I saw are painted blue and my engine is painted silver and that's what confuses me. Thanks.
Howard Sterndrive
Re: Omc 3.0 140 hp
no you don't, actually. A 3.0 from a 1986-1989 Cobra will work for you just fine.
If all you need is the long block engine, any 3.0 from 1970 to 1989 will BOLT RIGHT IN. It can be from any OMC, or Mercruiser powered boat with a 3.0L, 181 cubic inch GM Marine engine older than 1990
What you absolutely MUST AVOID, is a 1990 or newer 3.0L from any boat. Your drive coupler on the back of the crank will only work with engines 1989 and older.
Your drive is not a Cobra, it is a "400 Series Full Mechanical Shift Stringer Mount OMC Sterndrive" - or at least that will identify it well
Technically, according to OMC, your drive is simply a 983486
misiek
Re: Omc 3.0 140 hp
Is there a lot of difference in power and performance between the 2.5L and 3.0L engines? My boat is a 17 footer. There seems to be more of 2.5's available on the the market so should I consider them to replace my 3.0L with. Thanks.
Re: Omc 3.0 140 hp
Ayuh,... 20hp...
Resize your pictures,... They're Too Big... use 480x640....
misiek
Re: Omc 3.0 140 hp
I know it's 20 HP difference, but how does it translate to the overall performance? Speed? Pick up?
Howard Sterndrive
Re: Omc 3.0 140 hp
big difference.
you will notice the power difference immediately on holeshot and top speed.
15% less power
maybe do a search - pretty sure somebody was here cursing themselves for going the 2.5 route not that long ago...
CobiaXL
Banned
Re: Omc 3.0 140 hp
The best drive ever assembled..... JMHO
Sorry I just wanted to be included,lol
I will add that the 3.0 chevy block is same as 2.5
Good luck on your search
misiek
Re: Omc 3.0 140 hp
Just out of curiosity. Would a 165 HP MerCruiser fit as well? The inline 6 cylinder looks very similar. Can they be swapped?
coheej
Re: Omc 3.0 140 hp
The 2.5 has a 3.875" std. bore and the 3.0 has a 4.000" std. bore
