Having a start-up problem, Please help.
Symptoms: Need starter fluid when engine is cold, then after it starts up all is good for at least 30 minutes of running at all speeds. I have noticed though that it sputters while running, like it is starting to die, I have backed off the throttle then it starts running properly. When it is running poorly, I've noticed that the pulley connecting the belts to the alternator and supply pump (what is a supply pump?) quits turning.Are these problems related?
