OMC 3.0L cooling hoses not available
1992OMC302BMRAMH
Good day thanks for anyone’s help in advance im looking for replacement hoses for my 3.0L and they seem to be far and few between
Hoses (OMC number)
0311075 - L/P I can get this one from Volvo PN 3857391
3853255 - L/P I can find this one marineengine.com
0913489 - L/P but I can’t find this one
Any help would be great thank you
Honorary Supreme Mariner
Does MERCRUISER use the same hoses as the OMC / VOlVO on this 4 cylinder ?
Not Mercruiser, however VP may be close
What I would do. Go to gates website. Download the molded hose catalog, them measure your existing hoses, and spend a few hours finding the hoses under the gates numbers
Renken2000Classic
I took the gas fill hose (and maybe the vent too...) from an old truck to Napa. The counter guy took me back to their impressive radiator hose supply and we found something that worked (prob had to cut it down).
Might notta been the right thing to do (use a rad hose for that), but it's held for a few years now.
Another option...
docben
Another option...
Now, I'm looking for fuel hose, not cooling hose and my old one says, "Shields 310 USCG Type A Hose Fuel Fill 1983". Don't think any NAPA store has a Type A or A2 one that is USCG approved.
docben
I'm also looking for fuel hose and my old one says, "Shields 310 USCG Type A Hose Fuel Fill 1983". Don't think any NAPA one is USCG approved.
Internet lists this:
To order by the foot, enter the total quantity and we will cut to that complete length (not cut individual feet) 50 foot max.
  • 368 Series, ISO 7840 low permeation fuel hose
  • Hose built with plastic barrier veneer, polyester reinforcement and NBR (nitrile) outer layer tube
  • Complies with EPA and CARB low permeation requirements
  • Weather and UV resistant
  • ISO 7840 Type A1 and NMMA/CE type accepted standards
  • SAE J1527 Type A1-15
  • Meets USCG Type A1-15 requirements for pleasure boats
  • Temperature range: -20 Deg. to 212 Deg. F
  • 2 Year Emission Performance Warranty
Typical use is fuel feed for outboard, inboard/outdrive - Gasoline up to 85% ethanol blended fuels / Diesel / Bio-diesel all blends.
Renken2000Classic
Yes, boats are another matter; don't make any substitutes when it comes to the fuel system.
(To continue the topic shift/hijack)... That does look old; Can't readily access mine to see what it says on it. Looks heavy duty though and not ribbed like that. Black w/lengthwise maroon stripe (for what that's worth).
Cooling system on most marine engines is not under pressure.-----Temeratures are lower than automotive as well.
