OMC 3L Cobra rear main seal
Sugo
I have an 88 Bayliner Capri with an inboard. I am going to attempt to change the rear main seal in the OMC 3L Cobra. Does the leg have to come off to pull the motor out or can I just slide the motor forward once its lifted ? Worked on lots of cars and outboards but this is my first inboard.
Thanks for any tips.
Re: OMC 3L Cobra rear main seal
Ayuh,... Pull the drive 1st, then the motor lifts straight up...
The motor also has to be Realigned when reinstalled...
Gary H NC
The drive must be removed first. Also be sure to use an alignment tool when you get the engine back in and check the alignment before installing the drive.
( Dang Bond-o,that one finger typing beat me again..:p )
Sugo
Thanks for the help guys
Gary H NC
Sure! Welcome to Iboats!
While the motor is out inspect everything for rust and paint the oil pan good.
They are known to rust through...;)
Sugo
Good tip, The rear main seal is a 2pc seal. Can I slide the top half around the crank or do I have to remove the crank? Any tricks ?
Thanks
