OMC 4.3 1989 OIL CHANGE.
Pedrocasas
This will be the first time I do a oil change on this boat.
Is it just the engine oil, or is there also other parts that need oil or lube changed??
I heard the outdrive also needs a oil change.
Thank you guys!!!!
southkogs
Stern drive will need it's lube changed, but I don't know how it is done (specifically) on a Cobra.
bruceb58
When you change the gear oil on the Cobra drive, make sure you follow the instructions carefully. It is filled differently than other brands of drives. It is filled from a middle fill hole. Not from the bottom like other brands. Filling it from the bottom can destroy your drive.
Lou C
No Title
Engine oil you will need to use a vaccum pump, with an adapter to connect to the garden hose threads on the oil dipstick tube. The oil filter can be hard to reach depending on your access, I use cap wrenches that fit the filters I'm using. Used to use the long Sierra ones, those have been replaced by a shorter model, same with Merc/Quicksilver.
