OMC 4.3 Electronic Ignition Swap
Robobrainiac
Here are the fuel pump specs from my OMC shop manual:
5.5-7 PSI
Volume at cranking speed: 1 pint in 45 sec or less
Vacuum at cranking speed: 9-10" of mercury
Mine passed all of these tests, it took me a while to round up the fittings to do the tests safely due to the metal fuel line between the pump and the carb.
BTW you have the same boat and engine as I do.
Yours has a 4bbl Quadrajet correct?
Yes, I have the quadrajet. We had 3 years of trouble free use since I bought it. I put an impeller in it and battery and have had no issues until now. I should have been at least checking points. But we just drop it in and have fun. I look forward to getting it back on the water.
