whickety2007
Thread starter- Joined
- Jul 28, 2007
- 19
Re: OMC 4.3 knock at idle
MikDee....Yup went ahead with the new rings. Squared each one up in its appropriate cylinder with a piston to measure the end gap. It was typically around the 0.018 in. range give or take a thousandth. Installed the oil ring/s with the spacer's gap at 6 o'clock top oil ring at 8 o'clock bottom oil ring at 4 o'clock. The compression rings were installed with the top ring's gap at 2 o'clock and the second ring's gap at 11 o'clock both with the dot facing up. This is all in reference to the arrow on the top of the piston pointing toward the front of the motor. All were slathered in 30 weight, hose over the rod bolts, and punched carefully through the piston ring compressor. The oil pump was replaced, and the pickup tube welded to the pump after claying it to the bottom of the pan for about a 3/8" gap. You should have seen the old pump....scored and gored and full of crap.
Wire2...nice description of glyptal. I wont be using it in a motor again, but I will tell you guys that I coated my bilge with it 3 years ago, and it still looks great. Its got a nice reddish brown color. Plus, like you said, it's impervious to petrochemicals.
I dropped of the engine for installation today. When the engine came home, it was much easier to handle with no pan, and crank. I had to bolt a 7" piece of 4x4 to each motor mount and leave the top potion of my engine stand bolted to the bellhousing. The back just sat on some blocking. The whole thing was chained, and held down with a come-along.
Tonight the mechanic left me a voice-mail without much info..."This is Bob, please call me about putting your motor in". I'm a little worried he ran into trouble. Maybe its in, and running
Like I said a few days ago...The planets are going to have to align to get me off on a lake vacation by Saturday.
