weloveour7dogs
- Joined
- Aug 12, 2010
- 26
I have a 79 omc 400 outdrive that needs to be swapped out, I allready have the replacement one. the problem is I need to use my old shift cable (guy cut the one on the replacement) I can't feed the shift cable through the mid drive with out removing the brass keeper on the end of the shift cable. (only enough room to just get the cable though the holes)
does anyone know if the brass piece can be removed? is there a trick to get it off? and if I do get it off, I can put it back on right?
