I am currently restoring a 1994 Four Winns 180 Horizon SE with an 1993 OMC Cobra 5.0 190HP motor. Currently the boat has no throttle and hence no trim switch. I currently am needing to tilt up the outboard to move it. Is there a manual override I can use? If not how can I energize the tilt/trim motor without the switch?
Lastly, what engine manual do you recommend for the 1993 OMC Cobra 5.0 190HP on a 1994 Four Winns 180 Horizon SE?
Thanks All.
Kevin
Thanks All.
Kevin
