I own a 1987 four winns 190 horizon with omc 5.0l gm motor. I replaced the u-joints, gimbal bearing, motor coupling, coil, spark plugs, fuel filter/water separator, and opened up the carburetor to look at the float and found nothing unusual. I drained the gas tank and just added all new fuel. The issue is when running at WOT for longer than about 1 minute it will slowly start to slow me down then it will bogg the motor. After it boggs down and i give it speed again it feels like I'm getting some vibration, which doesn't last once getting up in rpms. usually it runs great getting to speed, and runs fine at 75% throttle. Any information on where to start looking would be great.
stock rpm gauge not working, have a 14.5 x 19 pitch prop with a max speed of 38 mph with me alone in the boat. carb is a Rochester quadra jet. motor runs at 160 max temp when at high rpm. oil pressure is from 10-40 lbs.
I'm a first time boat owner and have some mechanical knowledge. if this speed and everything seems off please let me know.
Thanks,
Thanks,
