Good Trout To You Sir
Thread starter- Joined
- May 22, 2018
- 85
See a number of 6HPs in this age bracket in my local market and wish to know what to expect if I pursue one of them.
Are there any substantive factory differences year-to-year within this 8-year span.
Is any particular year better or worse component-wise?
Was the kW power rating system the same as present day......such that 6hp then is comparable to 6hp now?
What's the bogey for threshold compression for these motors to run well throughout the RPM range?
What fails most often on 6hp OMCs of in this vintage?
Pushing a 15' flatbottom, would I gain noticeable speed from replacing the metal 2-blade prop with plastic 3-blade prop?
Is there a carb kit that includes a new float? (The kits that I see do not --- but perhaps I overlooked.)
Other than preventive maintenance of new coils, points, water pump ---- if you acquired a 6HP of this era with an unknown maintenance profile, what else would you preemptively replace?
Thanks.
Thanks.
