studdy05
Thread starter- Joined
- Mar 27, 2008
- 81
I have completely replaced the upper and lower units aluminum hulls that were rotting on an 84 stringer and tried to carefully reseal things back as I went. The impeller was trash...the upper had been sitting in water with little oil as it rusted out, but the gears looked good and the seals and bearings were not that hard to replace. After about 3 water tests, it seems at WOT it would run hot, but getting back down to 2000 RPMs would cool it off.
After rerouting a power steering cooler to a seperate radiator to increase the water flow directly to the engine from the sea water pump, I think I actually saw some improvement. While testing this out, skipping along at WOT for a half mile or so, my sterndrive lost power, no forward or reverse, and my engine temp headed to redline. I shut it down quickly, no harm no foul to the engine, but after reading/researching threads here and doing some checking, looks like the water pump drive shaft probably gave way.
Two questions: First, reading everything I could get my hands on, I still don't feel like I got a good seal on that impeller - it was the whole shebang kit and I will get another one just in case I need to replace something - but what is the trick to getting a good seal. The manuals seem a touch vague. Links appreciated if this has been beaten to death before. (I am seriously considering a 12v sea water pump mod. in the engine room to assist the OMC design)
Second, if I replace the water pump drive shaft because I stripped it, should I go ahead and order the upper pinion shaft that it connects to? I am seeing tons of people with stripped water shafts, but no comments about what that shaft slides in to...other than grease the fire out of it. Does the pinion shaft hold up better and the weak link is always the water shaft? (Generally speaking here.)
I have been stranded roughly 80% of the time I hit the water with this OMC drive and that is getting old. I don't mind spending the money, or the time fixing it, but I am about to run out of lakes to test on...friendly on goes so far...lol!
