mrollingthunder
Thread starter- Joined
- Aug 11, 2008
- 7
I have a 1978 Glastron with an 185 (chevy 350) and an OMC 800 outdrive. The tilt was working on the outdrive until last week. It worked on the way out, but when trying to raise the outdrive on the way into the dock it would not work. I checked all the electronics, they're fine. The tilt motor spins, the shaft is solid, the coupler oK. The motor is spinning and the shaft and worm gear spinning, but not raising the outdrive. The seal had failed on the tilt shaft, so when I opened the cover I had the typical oil and water "milkshake." I added a new seal, dried all the parts and reassembled the unit. Same issues. I took the cover off and found everything turning freely, including the clutch pack. So it appears the clutch is not engaging. Could it be the clutch pack needs replacing (probably at a cost greater than the value of the boat), or am I missing something?
